02-28-2024, 03:22 PM
I have an ABB IRC5 controlling an IRB 6640 on a IRBT 6004 track
I do not have acces to Robotstudio
I am using the flexpendant for controlling the IRC5 controller
I have followed this tutorial: ABB driver
Any help is appreciated
- Approach
I just try to use the robot without the rails: ABB IRB 6640-235/2.55I can ping the robotI can press connect get "succes"I can press "get position" and the RoboDK software updates the virtual IRB6640 robot position to match the real one ( GREAT! )I then try to move the robot a bit in RoboDKThen I try to press "Move Joints", to try to get the real robot to move to match the virtual robotThen I get the error: "Missing External Axis Value":40512, Missing External Axis Value Description Some active external axis have incorrect or no order value. Recommended actions Reprogram the position. The robot stops immediately after I have pressed "Move Joints"The error "Missing External Axis Value" might make sense since the IRC5 is set up to control both the IRB 6640 and the IRBT 6004 track - Approach
I try to synchronize the robot with the rails: IRBT 6004 tracks I can ping the robotI can press connect get "succes"I can press "get position". Now the virtual robot does not update the virtual IRB6640 robot position to match the real one ( NOT GREAT! ) I then try to move the robot a bit in RoboDKThen I try to press "Move Joints", to try to get the real robot to move to match the virtual robotThen I get the error: "Speed too low":50381, Speed too low. Description Task. arg The speed is too low (numerical resolution). Program Ref. arg Recommended actions Increase the programmed speed. Check also the other synchronized tasks in a multimove application.I hear the motors turning on for a second (a clicking sound), but the robot stops immediately after I have pressed "Move Joints"
