05-07-2025, 11:35 AM
You can perform a linear movement to a joint target to move to the same target with different joints.
Request to add robot Neura MAiRA Pro S |
05-07-2025, 11:58 AM
Thank you for your response.
However, with conventional 6-axis robots, we almost always have the option to freely choose the robot configuration. In the case of a 7-axis robot, this is not possible — only one configuration option is shown (see the image in the attachment). Is it also possible to define the desired configuration in a similar way for a 7-axis robot? Best regards! Mitja
05-09-2025, 01:55 PM
(This post was last modified: 05-09-2025, 01:57 PM by Mitja GOLOB.)
Hello!
Is there already any information available as to why it is not possible to freely select configurations with a 7-axis robot, while 6-axis robots do not have this issue and the robot configuration can be freely determined? I have also attached an image above that illustrates this issue. Thank you and best regards, Mitja
05-13-2025, 09:58 AM
7-axis robots like the Neura MAiRA PRO S robot use iterative inverse kinematics methods.
Alternatively, we could model this robot like the KUKA LBR IIWA attached which allows you to choose the angle of the arm using a slider right under the target pose. |
| 2 Guest(s) |
