How can I offset and copy the programs/paths?
Hi all,
These days I created so many paths, But in my case, I must create some many same paths. So I want to copy and offset the current path.
Can you show me the tutorial,Can not find the Copy/offset functin for the paths.
You should be able to simply "Copy/Paste" the path from your station tree, double click on it to open the "Object Details" window.
Select "More options", then offset the position of the path with respect to the reference frame.
Finally, "Apply move".
If the path is imported from a CAD plugin (SolidWorks, Inventor, Fusion, Solid Edge, etc) I recommend you use the "Import Curves" and not the "Auto setup".
