Modify kinematic parameters dynamically or create targets as variables
Is there any workaround to modify kinematic parameters dynamically? I have the measurements and I know the deviation of each robot joint during the warm-up period and I would like to modify the kinematic parameters as a function of time or temperature. Or it is possible to create the targets as variables (via script or a modified post processor ?).
What I am trying to achieve is to correct the robot targets or joint values during the warm-up period in hope of improving at least a little the robot's repeatability or precision.
Does anyone knows if it is possible to add such a parameter in the robot programming file (external temperature or at least a time counter from the robot start) and create some variables function of these?
Cozmin
Hi Cozmin,
Take a look at this: https://robodk.com/doc/en/PythonAPI/exam...t-model-dh
Hello again,
I am still struggling a little with trying to modify some kinematic parameters of IRB 140 robot. Is there any way to model a mechanism that has more parameters ? What I mean is I have placed the reference frame of each joint as close as I could in their real positions.  That means reference frames are not all aligned in a middle plane.
Do you think is any workaround to create such mechanism and compute inverse-kinematic?
Check attached images, it will be much clear what I mean.
Thank you,
Cozmin
