Real-time moving of real robot using Robodk with MATLAB API
I am wondering is it possible to move the real robot in realtime mode while the path is generating in MATLAB software?
This ability is able to move the robot in Robodk environment while MATLAB is generating the path. Then, to be specific is it possible to move the real robot as it is moving in the Robodk environment, simultaneously?
Yes, this is possible. You should be able to run the robot directly from Matlab code by using the RoboDK API for Matlab.
This example shows the concept in Python:
https://robodk.com/doc/en/PythonAPI/exam...rogramming
The Python and Matlab API are very similar so you can code this in Matlab.
