Crash when generating program from python script for Yaskawa GP50
Environment:
  • RoboDK Win 64 bit version 5.6.5
  • Windows 11
  • Yaskawa GP50 base robot model
Steps to reproduce:
  • Use Yaskawa GP50 robot
  • Create a python script (in my case I used draw hexagon example)
  • Left mouse button on the python script > Generate robot program (or F6)
  • The application shows loading indicator and suddenly crash
Windows EventViewer shows .NET runtime error and he following application error
Name of the application that generated the error: RoboDK.exe, version: 5.6.5.23784, timestamp: 0x651e931d
Name of the module that generated the error: RoboDK.exe, version: 5.6.5.23784, timestamp: 0x651e931d
Exception code: 0xc0000005
Error offset 0x000000000a02d9
Process ID that generated the error: 0x0xA798
Start time of the application that generated the error: 0x0x1D9FB4C38609441
Path of the application that generated the error: C:\RoboDK\bin\RoboDK.exe
Path to the module that generated the error: C:\RoboDK\bin\RoboDK.exe
Report ID: 975a2112-9783-495d-91c7-4ebd2ca183eb
Full name package that generated the error:
Application ID related to the package that generated the error:
Many thanks
Can you share the RDK project file that provoked this error?
I'm unable to reproduce this issue using the latest version and the hexagon weld script example.
(10-10-2023, 09:27 AM)Albert Wrote: Can you share the RDK project file that provoked this error?
Yes sure, you can find it in attachment.
I think that the problem is not related to the python script itself, since the crash happens also with default python script.
.rdk   GP50_test.rdk (Size: 4.79 MB / Downloads: 102)
I'm unable to reproduce this issue. I recommend you to set the default settings and try again:
  1. Select Tools-Options.
  2. Set Default settings.
If the issue persists, to debug this issue better it would help if you can follow these steps:
  1. Start RoboDK by double clicking the file:
    C:/RoboDK/RoboDK-Debug.bat
  2. Try to reproduce the problem in RoboDK until it crashes.
  3. Right after the crash, provide us with this file:
(10-10-2023, 11:17 AM)Albert Wrote: I'm unable to reproduce this issue. I recommend you to set the default settings and try again:
I reset the setting to default as you suggested with no luck.
In attachment you can find RoboDK.debug.txt file.
thank you
.txt   RoboDK.debug.txt (Size: 11.05 KB / Downloads: 88)
Tried also with a fresh installation but the crash still occurs.
Tried on another PC and it works.
Let me know if you need further details to diagnose the problem.
Many thanks
