DOBOT CR Post Processor - No module named 'dobot_api'
I'm working with RoboDK on Mac and I imported the Dobot CR post processor, however, when I try to manually run the generated program on my Dobot CR10, I receive the following error in the attaching image. Any way I can work around this?
Thank you!
You should place the attached dobot_api.py file in the same folder where your programs are generated.
.py   dobot_api.py (Size: 32.38 KB / Downloads: 184)
That worked, thank you so much! Something I noticed when manually running the generated script on the CR10 was that the joint moves worked as expected, however, the linear moves didn't work on the CR, and the robot wouldn't move when it reached a linear move on the script. Is this a known issue and if so, is there a fix for this? Let me know if you need additional information. Thank you!
