Machining project Update followed immediately by RunCode doesn't work
In the attached station, the following does not result in the program being executed:
from robodk import robolink
rdk = robolink.Robolink()
machining = rdk.Item("Path1 Settings")
program = rdk.Item("Path1")
machining.Update()
program.RunCode()
But the following (with a time.sleep(0.5)) does result in the program being executed:
import time
machining.Update()
time.sleep(0.5)
program.RunCode()
It's not deterministic and depends on the amount of time between the Update and the RunCode. Note that Path1 is the generated program for the Path1 Settings machining project.
Please advise; how do I deterministically ensure that a program run following a machining project update always runs?
On macos. "About" menu item shows RoboDK v5.5.0.22337 but rdk.Version() shows '5.4.3.22337'.
.rdk   update-run-code-example.rdk (Size: 3.4 MB / Downloads: 189)
Thank you for your detailed report. We fixed this issue on 1 week ago on Windows. We'll update Mac and Linux versions before the end of the year.
