  • 1 Vote(s) - 5 Average
Collision Avoidance
#21
(04-30-2019, 07:39 PM)Albert Wrote: Hi Robin,
Thank you for your feedback. There is a new update that includes the option to save your samples and the edges matrix through the API as CSV files. As an example, you can use the following code:
current_rdk_file = RDK.getParam("FILE_OPENSTATION")
# Save the N samples as a CSV file: joint values will be saved as one row per set of joints
status_msg = RDK.PluginCommand("CollisionFreePlanner", "SaveSamples", current_rdk_file + "-Joints.csv")
print(status_msg) # Returns "Done" if it worked
# Save the map as a CSV file (matrix of size NxN)
status_msg = RDK.PluginCommand("CollisionFreePlanner", "SaveMap", current_rdk_file + "-Map.csv")
Hi Albert, thanks for this usefull tip
But I do not find any documentation on SaveSamples and SaveMap on the API doc , is there an other link for a updated documentation ?
Thank in advance,
Have a good day
#22
Unfortunately we don't have documentation about this special API feature. The sample code I sent you works and creates a CSV file.
#23
(03-22-2019, 02:20 PM)Albert Wrote: Hi Robin,
Thank you for your feedback. We'll open a command so you can trigger a PRM update through Python. It will take 2 weeks or so.
For now, you can connect 2 targets or 2 programs through the API. For example, if you want to connect Target1 and Target2 creating a program called SafeMove you can do:
status = RDK.PluginCommand("CollisionFreePlanner", "Join", "Target1|Target2|SafeMove")
I was unable to reproduce the AddFile issue. You should make sure RoboDK is not busy updating the PRM map or connecting 2 targets, otherwise you may see a timeout issue.
What other commands would you need?
We are currently preparing more material to support this feature.
Hey Albert,
I am trying to run this command in my python script:
mbox('before')
status = RDK.PluginCommand("CollisionFreePlanner", "Join", "Target 1|Target 2|Path")
mbox('after')
I can see `before` message, then it simulates the motion from Target 1 to Target 2. But I never see `after` message. Am I loosing control flow somehow?
Thanks in advance,
Yury
#24
It may take some time to joint these 2 targets. Do you see any other messages?
If you can provide your RoboDK project file we can better take a look.
#25
Sure, here it is. The code is in the FindPath python file.
TIA,
Yury
.rdk   b-sample.rdk (Size: 1.94 MB / Downloads: 885)
#26
Everything works just fine if I drop 'Base' item under the robot
#27
FYI, you can find more information about the Collision Free planner plugin here:
https://robodk.com/addin/com.robodk.plug...reeplanner
