I'm not sure if this is actually a RoboDK problem or a generic Kuka problem, but I haven't been able to get an answer from Kuka and it is related to RoboDK programs. We recently had Kuka come out to do their calibration for one of our robots, and, ever since then, we have been unable to run RoboDK programs when the absolute accuracy is enabled. Whenever we do, the robot will go to BCO, then immediately error once it tries to move to the first point. The error says, "KSS03182 Absolute Accuracy: model error is too great." However, if we disable the absolute accuracy, we can run the program fine. But this doesn't help us because disabling that essentially nullifies our calibration.
We read in other forums that it might be related to the mass variables for our head, so we experimented with that, but nothing has changed. But, yesterday, we started experimenting with creating our own programs by manually teaching the robot points through the pendant using the same end-effector and points similar to the points in our failed programs, and we were able to run. So, there is something different between the RoboDK program and the taught program that causes the RoboDK program to fail with the absolute accuracy enabled.
Has anybody encountered this problem before? Any ideas on what might be causing it?
Thank you!
Thank you!
