Target coordinates using the KUKA KRC4 driver
#11
Hi Albert
Yes, i am using your project.
I joined you my robodksync. I put the command gb2_frame(outil_actuel, 2) that assign the base to 2. It is equivalent to $BASE = BASE_DATA[2] but i am not sure it is the problem. I repeat when i used the src file generated by the post pro, everything is fine but i can't use this way i have to do it online.
Thank you for your help, i hope we can fix this issue, i have practical exercice with my students soon.
Bye
Cyril
.src   robodksyncgb2vireur.src (Size: 4.24 KB / Downloads: 561)
