09-13-2022, 07:04 PM
(09-03-2022, 06:06 PM)Albert Wrote: Copy-pasting objects with textures is not supported. We'll add support for this in the near future.
As a workaround, you can save your RoboDK station as an RDK file, manually rename it to RDKA and open it again on another project. Every time you add an RDKA file it will load the saved station inside the active station.
If you can provide the RDK file that was causing issues we can better investigate how we can prevent this crash from happening.
I tried your workaround but it does not seem to work. Every time I load a new RDKA file, the texture of the previous RDKA file goes away.
