For some reason when simulating gcode everything else runs fine xyz coordinates are correct and the toolpath shows like it should but the A, B and C degrees which defines the orientation of the robot doesn't simulate. So the orientation is always fixed altough the code is kind of non planar. Do I have to modify it somehow for simulation or is there some settings in robodk to make it work? This code has been tested and it works like it should on the machine.
| 2 Guest(s) |
Powered by MyBB
