ABB Controller 40700 Syntax error
We uploaded a .prg file on an ABB robot and the teachpendant gives the following error when trying to run it.
40700 syntax error: E, line = 6,  column =8:
Identifier MOD_flagstationtest too long.
This is the test code we are running:
  VERSION:1
  LANGUAGE:ENGLISH
MODULE MOD_flagstationtest
PERS tooldata rdkTool := [TRUE,[[0,0,0],[1,0,0,0]],[20,[0,0,200],[1,0,0,0],0,0,0.005]];
PROC flagstationtest()
!Program generated by RoboDK v3.5.4 for ABB IRB 6400R 2.8 200 on 21/04/2019 10:46:15
!Using nominal kinematics.
MoveJ [[1631.370,157.485,2844.633],[0.85716730,0.00000000,0.51503807,0.00000000],[0,0,-1,1],[9E9,9E9,9E9,9E9,9E9,9E9]], v1, fine, rdkTool;
MoveJ [[1708.946,690.459,2512.502],[0.77877720,-0.11615716,0.59757677,0.15137895],[0,0,-1,0],[9E9,9E9,9E9,9E9,9E9,9E9]], v1, fine, rdkTool;
WaitTime 1.000;
ENDPROC
ENDMODULE
Doese anybody know what might be the issue
As the error says:
The program or module name is too long.
Older ABB controllers such as S4 do not accept such long module or program names.
I recommend you to shorten the program name (flagstationtest) to 8 characters or less.
Do you know the exact limit in terms of characters?
We'll make sure we prevent creating such long names with the post processor.
(04-21-2019, 02:35 PM)Albert Wrote: As the error says:
Well we solved it by just changing the name. It doesn't need to be that long for us. Thanks for the help. We made the mistake to think that the program name length wouldn't be a problem.
