09-27-2022, 07:56 PM
(This post was last modified: 09-27-2022, 08:03 PM by Julian Holcroft.)
I am trying to program general moves for my AR2 using RoboDK when I try to connect to it I get this error. How do I fix this?
Starting robot driver: C:/RoboDK/api/robot/AR2Driver.py
Starting...
Not started
Sending command...
Installing required module: pyserial ...
Running command:
C:\Users\Julian Holcroft\AppData\Local\Programs\Python\Python38\python.exe -m pip install serial
Requirement already satisfied: serial in c:\users\julian holcroft\appdata\local\programs\python\python38\lib\site-packages (0.0.97)
Requirement already satisfied: future>=0.17.1 in c:\users\julian holcroft\appdata\local\programs\python\python38\lib\site-packages (from serial) (0.18.2)
Requirement already satisfied: iso8601>=0.1.12 in c:\users\julian holcroft\appdata\local\programs\python\python38\lib\site-packages (from serial) (1.0.2)
Requirement already satisfied: pyyaml>=3.13 in c:\users\julian holcroft\appdata\local\programs\python\python38\lib\site-packages (from serial) (5.4.1)
Unable to load or install pyserial. Make sure you have internet connection and administrator privileges
Unexpected error: Traceback (most recent call last):
Unexpected error: File "C:\RoboDK\Python\robodk\robolink.py", line 492, in import_install
Unexpected error: exec('import ' + module_name, globals())
Unexpected error: File "<string>", line 1, in <module>
Unexpected error: ModuleNotFoundError: No module named 'pyserial'
Unexpected error:
Unexpected error: During handling of the above exception, another exception occurred:
Unexpected error:
Unexpected error: File "C:\RoboDK\Python\robodk\robolink.py", line 526, in import_install
Unexpected error:
Unexpected error:
Unexpected error: File "C:/RoboDK/api/robot/AR2Driver.py", line 26, in <module>
Unexpected error: exec("from v" + version_str + ".AR2Driver import *")
Unexpected error: File "C:\RoboDK\api\robot\AR2Driver.py", line 12, in <module>
Unexpected error: import os
Unexpected error: File "C:\RoboDK\api\robot\AR3Driver.py", line 26, in <module>
Unexpected error: exec("from v" + version_str + ".AR3Driver import *")
Unexpected error: File "C:\RoboDK\api\robot\AR3Driver.py", line 67, in <module>
Unexpected error: File "C:\RoboDK\Python\robodk\robolink.py", line 534, in import_install
Unexpected error: raise Exception(msg)
Unexpected error: Exception: Unable to load or install pyserial. Make sure you have internet connection and administrator privileges
Stopped
Here are the connection settings I am using
Starting...
Not started
Sending command...
Running command:
Unexpected error:
Unexpected error:
Unexpected error:
Unexpected error:
Stopped
