Alternate linear gage sensor options in Japan
Hello, our customer is interested in Twin Tool and tries purchasing a linear gage sensor compatible with Twin Tool.
Some items on the online documents are not available in Japan, so could you check the Mitutoyo 542-080 can be used as an alternate option? Please check the document attached on the post.
Also, we would like to know if other materials/videos are available except for the documents as it looks complicated to implement measurements.
Best Regards,
.pdf   542-080.pdf (Size: 256.52 KB / Downloads: 405)
RoboDK TwinTool should be compatible with this Mitutoyo linear gage if the connection works like all standard Mitutoyo connections (like traditional COM ports).
Could you contact us by email and put us in touch with the customer? We can provide you with a test license and run quick test to check the compatibility and improve it if necessary.
