Assign custom driver to a robot/mechanism from the api
Hi all,
How can i do this from the robolink api?
RoboDK links to a specific driver in the robot connection settings:
1.Right click a robot
2.Select [Image: image001.png] Connect to robot…
3.Select More options…
4.Locate or enter the path of the driver path in the Driver path section
Best Regards,
Nedko
You can change the Driver path by using the robot parameter PathDriver using the API.
Example code:
# Update the driver:
robot.setParam("PathDriver", "your-driver-file.py")
# Get the current driver:
driverpath = robot.setParam("PathDriver")
print(driverpath)
You can find the same question posted here:
https://robodk.com/forum/Thread-Select-d...RoboDK-API
