Attach a tool to an Item that's not a robot
Hi everyone,
I need to export an Item from RoboDK as a tool because I need it to have its own zero and  a fixed frame on the surface (basically the zero where the flange is and the frame where the suction cups are, in the case of a gripper).
I then need to load this tool and attach it to an object that's not a robot, keeping the two frames alive.
If I try to drop my tool under another item, it gets changed to a generic item and it loses the suckers frame.
Is there a way to accomplish this?
Thank you!
Yes, you can accomplish converting a tool to an object and vice versa with a custom script.
For example, you can do this to drop the tool:
tool.setParentStatic(reference)
tool.setParam("Convert", "Tool")
And you can do this to pick it up:
tool.setParam("Convert", "Object")
Thank you a lot! I missed this command in the list. It works perfectly
