Threads: 1
Good morning.
I would like to attach an object to an axis (arm) of the robot.
Suppose that I need to put a small box fixed in the axis 4. This box should move along with the axis 4, to allow me to check collisions.
Is it possible?
Thanks in advance.
Threads: 1
Hi Jeremy.
It works properly.
Thanks.
74
Press the same keys and select "No".
It should exit the dev mode.
If it doesn't, just restart RoboDK.
Threads: 5
11-08-2021, 09:32 AM
(This post was last modified: 11-21-2024, 12:00 PM by Albert.)
After doing "setp2 - Add_Object_To_Robot", there's no response from RoboDK.
Basically, with my DK-5.3.0, there's no script of "Run Script" can output any response.
I could run post process script, so the Python settings seems to be fine.
How should I proceed with the "Run Script" issue?
74
Yishin,
Are you saying that none of your script are working?
Could you give it a go to ScaleXYZ?
It's a very simple script and you should see if it works right away.
