01-17-2023, 08:04 PM
(This post was last modified: 01-17-2023, 08:17 PM by sig.johnnson.)
In the C API, Item_SolveIK() is:
I notice that the behavior for when a tool or reference frame is passed has been commented-out.
This is not the case for the C++ and Python API. (C++ below).
Does the C call behave the same as the Python and C++ API calls?
If not, would it work if I just uncommented the relevant lines or were they commented-out due to problems?
Update: I think I partially answered my own question here. It looks like struct Mat_t has no ->inv() value, so I think uncommenting would not work at all.
Here's some code that might fix only the tool feature. Would this work?
struct Joints_t Item_SolveIK(const struct Item_t* inst, const struct Mat_t* pose, const struct Mat_t* tool, const struct Mat_t* ref) {
struct Joints_t jnts;
struct Mat_t base2flange = *pose; //pose of the robot flange with respect to the robot base frame
if (tool != NULL) {
//struct Mat_t poseInv;
//Mat_Inv_out();
//base2flange = pose * tool->inv();
if (ref != NULL) {
//base2flange = (*ref) * base2flange;
_RoboDK_check_connection(inst->_RDK);
_RoboDK_send_Line(inst->_RDK, "G_IK");
_RoboDK_send_Pose(inst->_RDK, base2flange);
_RoboDK_send_Item(inst->_RDK, inst);
jnts = _RoboDK_recv_Array_Joints(inst->_RDK); //&jnts VS
_RoboDK_check_status(inst->_RDK);
return jnts;
}This is not the case for the C++ and Python API. (C++ below).
tJoints Item::SolveIK(const Mat &pose, const Mat *tool, const Mat *ref){
tJoints jnts;
Mat base2flange(pose);
if (tool != nullptr){
base2flange = pose*tool->inv();
if (ref != nullptr){
_RDK->_check_connection();
_RDK->_send_Line("G_IK");
_RDK->_send_Pose(base2flange);
_RDK->_send_Item(this);
_RDK->_recv_Array(&jnts);
_RDK->_check_status();
return jnts;
}Does the C call behave the same as the Python and C++ API calls?
if (tool != NULL) {
//Mat_Inv_out();
struct Mat_t temp;
Mat_Inv_out(&temp, tool);
Mat_Multiply_out(&base2flange, &pose, tool);
if (ref != NULL) {
return jnts;
