10-12-2023, 12:14 AM
I am having some difficulty using the C++ API to connect to RoboDK on a specific port. Can you please provide an example of doing this?
My specific use case is inside a class instance, connecting to an existing instance of RoboDK that was already started by another process. I can pass either pass the desired port number to connect to to the class constructor or to an init() method, but I do need to be sure that the class variable RDK is linked to that specific port number. The RDK variable needs to be available to all other class methods.
