CAD to Path
I found in the documentation that RoboDK has the CAD to Path feature but I didn't find how to use it:
1- I need the tcp to follow an edge of a part
2- I need to keep the TCP at 30 ou 45 degrees on the whole path
3- is it possible to display the targets generated in the tree?
Thank in advance
Hi mamara,
There are different ways of using the CAD to Path features of RoboDK.
Do you use a CAD software (3D modeling)? If so, the best solution would be to use one of our supported plugin: see the "plugin" section of the online documentation https://robodk.com/doc/en/Getting-Started.html#
