CAMWORKS 5 Axis Machining
Hello
Im new on Robodk.I have Fanuc Robot and  I'm trying to do 5 axis machining with camworks.When I use "roughing" in 3 axis mill its okey.
But , in 5 axis milling I have problems with robodk.
This is my NC file
Thank you.
.nc   Parça1.nc (Size: 169.51 KB / Downloads: 462)
Your NC file is 5-axis g-code specific to a machine as you are using A and C angles. You could use the IJK vector to specify the orientation.
Alternatively you can use APT output which exports the orientation as an ijk vector by default.
