CSV file to Program (XYZ). Python script failed
I have tried to use the example "6.6. CSV file to Program (XYZ)", but get an error on the Python script.
I would like to use this example to make a robot movement in the Z-direction with varying robot speed.
Can you solve the error in the Python script or show in a video how the script should be used with an Excel document/ CSV file?
Best regards
Jonas Jensen
Attached Files Image(s)
.rdk   Import CSV.rdk (Size: 1.98 MB / Downloads: 598)
.py   ImportCSV_XYZ.py (Size: 5.16 KB / Downloads: 415)
Are you running the script from RoboDK? You can do so by drag and dropping the Python script into RoboDK.
You can also trigger scripts from the C:/RoboDK/Library/Scripts without adding them to your project by selecting:
Tools-Run Script
I would recommend you to install the latest version of RoboDK and select Tools-Options and click on Set default settings so RoboDK uses the Python embedded version that comes with the latest version of RoboDK.
