11-21-2023, 07:41 AM
(This post was last modified: 11-21-2023, 07:49 AM by JaeHong Yoo.)
I want to use python robodk api to get the value of the 6 axis of my 6-axis robot from end-effector using the value of LIN {} which is the data in KUKA's *.src file. Also, I want to get a two-axis turntable while controlling it.
So I'm trying to get it using SolveIK_All(), but it's not going as well as I thought. Can you look at my code and let me know what the problem is?
For your information, if you look at my code, the value corresponds to LIN {} for the parameter of SolveIK_All(), the value of tool is the value of my 6-axis robot, and the value of my turntable for reference.
LIN {} that I will use Examples of data include: LIN {X 0.0001,Y -4.7575,Z40,A -2.9196,B0,C0,E1 0.1598,E2 90.075}
I want to know the robot's joint values when the end-effector of my robot arm is located in a position that is x, y, z away from the turntable, and rotates by a, b, and c, and my turntable is rotated by e1, e2.
P.S Additionally, I would like to know the joint values of the 6-axis robot when the end-effector moves to the corresponding coordinate when I receive a specific coordinate value with KR 70 R2100_2.4 station as the global coordinate. I would appreciate it if you could tell me these methods as well.
![[Image: figure1.png]](https://i.ibb.co/TMBjVQX/figure1.png)
from robodk.robomath import *
from robodk.robodialogs import *
from robodk.robofileio import *
from robodk.robolink import *
from robodk.robolinkutils import *
# Start the RoboDK API
RDK = Robolink()
# Ask the user to pick an SRC file:
rdk_file_path = RDK.getParam("C:/Users/JaeHongYoo/WRL Dropbox/Jaehong Yoo/RoboDK")
# src_file_path = getOpenFileName(rdk_file_path)
src_file_paths = getOpenFileNames(rdk_file_path, "Select SRC Files", "*.src")
if not src_file_paths:
print("Nothing selected")
quit()
# Process each selected SRC file
for src_file_path in src_file_paths:
# Get the program name form the file path
program_name = getFileName(src_file_path)
program_name = program_name.replace('_', '').replace('(', '').replace(')', '')
print("Loading program: " + program_name)
# Check if the file extension is .src
if not src_file_path.lower().endswith(".src"):
print("Invalid file selected: " + src_file_path)
continue
def GetValues(line):
"" "Get all the numeric values from a line"""
line = line.replace(",", " ")
line = line.replace("}", " ")
values = line.split(" ")
list_values = []
for value in values:
try:
value = float(value)
except:
continue
list_values.append(value)
print("list_values: ")
print(list_values[:6])
return list_values
# Open the file and iterate through each line
with open(src_file_path) as f:
count = 0
for line in f:
# Remove empty characters:
line = line.strip()
print("Loading line: " + line)
# Get all the numeric values in order
values = GetValues(line)
values_str = str(values)
# Increase the counter
count = count + 1
# Check operations that involve a pose
if len(values) < 6:
print("Warning! Invalid line: " + line)
continue
# Check what instruction we need to add:
if line.startswith("LIN"):
# Ask the user to select a robot (if more than a robot is available)
robot = RDK.Item('KUKA KR 70 R2100', ITEM_TYPE_ROBOT)
joints = robot.Joints()
joints[6] = values[6]
joints[7] = values[7]
robot.setJoints(joints)
RDK.ShowMessage('Turn-table has changed!', True)
# Get the active tool frame
tool = robot.Tool()
tool_str = str(tool)
RDK.ShowMessage('tool: ' + tool_str, True)
target_position = values[:3]
target_ori = values[3:6]
target_ori_temp = target_ori[0]
target_ori[0] = target_ori[2]
target_ori[2] = target_ori_temp
target_external = values[6:8]
radian_x = target_ori[0] * (math.pi / 180)
radian_y = target_ori[1] * (math.pi / 180)
radian_z = target_ori[2] * (math.pi / 180)
target_pos = transl(target_position) * rotx(radian_x) * roty(radian_y) * rotz(radian_z)
baseline = RDK.Item('Baseline')
baseline_pose = baseline.Pose()
baseline_pose_abs = baseline.PoseAbs()
KUKA_Base = RDK.Item('KUKA KR 70 R2100 Base')
KUKA_Base_pose_abs = KUKA_Base.PoseAbs()
baseline_rel_pose = invH(KUKA_Base_pose_abs) * baseline_pose_abs
relative_pose = invH(baseline_rel_pose) * target_pos
#all_solutions = robot.SolveIK_All(relative_pose, tool, baseline_pose_abs)
all_solutions = robot.SolveIK_All(relative_pose, tool, baseline_rel_pose)
joints_list = []
# Iterate through each solution
for j in all_solutions:
# Retrieve flags as a list for each solution
conf_RLF = robot.JointsConfig(j).list()
# Breakdown of flags:
rear = conf_RLF[0] # 1 if Rear , 0 if Front
lower = conf_RLF[1] # 1 if Lower, 0 if Upper (elbow)
flip = conf_RLF[2] # 1 if Flip , 0 if Non flip (Flip is usually when Joint 5 is negative)
# Look for a solution with Front and Elbow up configuration
# if conf_RLF[0:2] == [0,0]:
if rear == 0 and lower == 0 and flip == 0:
print("Solution found!")
joints_sol = j
joints_sol_str = str(joints_sol)
robot.setJoints(joints_sol[:6] + values[6:8])
RDK.ShowMessage('SolveIK_All: ' + joints_sol_str, True)
break
RDK.ShowMessage("Done", False)
