Calibration with new method using dial indicators?
Hi, is it possible to calibrate robots using robodk with the above method? I contacted the maker of the device and they say robodk will implement the above method. If so, when can we expect this to come? It is very low compared to using a laser tracker, which cost couple times more than a robot and software compared.
It is better if you send us an email regarding robot calibration with a dial indicator.
What accuracy are you trying to achieve?
Are you planning to calibrate the TCP, the robot or both?
(02-24-2020, 05:22 PM)Albert Wrote: It is better if you send us an email regarding robot calibration with a dial indicator.
For both, so I can achieve max repeatability and accuracy.
