Can Robodk read APT only X,Y axis (not z) ?
I have file apt with only X,Y axis for laser cutting, but robodk not read, is there any solution?
Thanks.
Attached Files Image(s)
The APT format requires at least XYZ coordinates. You should use G code instead.
What software are you using to generate this file?
