Can't find a start point and The robot cannot reach all targets
I'm working with a Yaskawa GP-50 robot combined with a custom H-Bot system.
In this setup, we are using only the X and Y axes of the H-Bot, and the Z axis is fixed (set to a constant value of 0, i.e., -0 ~ 0).
Here’s what I’m doing:
  • I generate a path in SolidWorks and import it into RoboDK.
  • In the Curve Follow Project, I apply the following settings:
    • Enable Axes Optimization
    • Enable Move External Axes
    • Lock J9 (Z-axis) of the external axes
    • Set the path to Start from here
However, I encounter the following problems:
  • When I click "Generate program", I get the error: "Can't find a start point"
  • When I click "Show estimated tool path", I get: "The robot cannot reach all targets in the path"
Has anyone faced a similar issue or know how to resolve this?
I would really appreciate any help or advice!
Thank you in advance!
It looks like you modelled your gantry system with the range of one of the axis blocked at 0 mm. I recommend you to provide some range, even if it is small (for example, from -0.1 mm to +0.1 mm), so that RoboDK can find a valid solution.
You can also use the optimization settings to force this axis to remain at 0 mm.
Another option is to model your 3-axis gantry as a 2-axis mechanism if you don't use that 3rd axis.
I also noticed that you didn't add a tool/TCP. I recommend you to add a TCP, even if it is virtual and at the location of the robot flange.
.rdk   0620_PathTest_Rev.3.rdk (Size: 17.98 MB / Downloads: 313)
