Cannot dictate tool origin in point following
If my points .txt file contains only x,y,z positions I can select them in the point following utility.
10, 20, 30  and the simulation will work as expected.
15, 20, 30
20, 20, 30
25, 20, 30
However, if I add A,B,C orientation values the same points display,
10, 20, 30, 0, 0, 0
15, 20, 30, 0, 0, 0
20, 20, 30, 0, 0, 0
25, 20, 30, 0, 0, 0
I can select them in the utility but I get the "can't find a start point" error although I am able to easily maneuver the robot to each point.
How may I specify a tool orientation for a list of points?
Thanks,
Jeff
See attachment.
.rdk   Simple 5 point following.rdk (Size: 1,021.74 KB / Downloads: 789)
Hi Jeff,
I answered this question in your last thread.
https://robodk.com/forum/Thread-Dictatin...ng-Project
The point orientation DO NOT follow the A, B, C rule used by KUKA.
You need to use a unit vector i, j, k.
