Cannot import program on TM Flow
#11
Hello, in my case it has not worked this way, I explain how(I answer in another colour)
1 - Name the TMROBOT USB drive (this step is important). Done
2 - Create a new folder called TM_Export in the root of the drive. Done
3 - Create a new folder inside TM_Export with your project (any name should work). In my case no, the folder must be named as the Cobot assigns it to me, otherwise it doesn't work (CCxxxx-xxxxx)
4 - Create a new folder inside the previous folder called Projects. Done
5 - Place the ZIP programs inside the Projects folder. Done
The USB drive name and directory tree inside TM_Export is important, otherwise you will not see the robot driver files. You can still use this USB drive for other purposes if you do not alter the directory tree inside the TM_Export folder. This also appears in the TM documentation
It only happens to me with programs imported from RoboDK, moreover, if I try to import a program created inside RoboDK to the TM-Flow desktop version, as there is no Cobot assigned (the one assigned by default by the software has no ID), I can not import the program, I do not know if it is my problem or some kind of bug, I hope this prevents someone from having the same problem.
Sincerely
