Change RoboDK light display options
Is it possible to change the light rendering settings ?
I have a setup that is hard to display because of the light shading in the application.
I would like to turn off or tune the light settings so the part faces are more visibles.
Do you know how i could do it ?
Thank you.
.mp4   Screen Recording.mp4 (Size: 869.02 KB / Downloads: 223)
You may need to swap surface normals to properly display your 3D model.
You can follow these steps, to change colours or swap surface normal:
  1. Select Tools-Change color tool.
  2. Select an object or surface.
  3. Right click on the desired colour and select the option Invert normals.
How did you create your 3D model? Can you send us a sample?
I'm not allowed to share the 3D model but the Invert normals tool fixed the display issue.
Will remember this tool!
Thanks.
Thanks for letting us know. I'm happy to hear the fix worked.
