Changing 'Active Tool' with Python
Hello!
I have several tools mounted on the same robot. To work with them independently I use setVisible property, but I did not find how to change 'Active Tool' parameter with Python. Is it possible?
Thank you in advance!
Yes, this is possible using setPoseTool(). You can set the active tool as an item or as a pose. You can also use setPoseFrame for reference frames.
More information here:
https://robodk.com/doc/en/PythonAPI/robo...etPoseTool
Thank you!
(02-19-2019, 11:49 AM)Albert Wrote: Yes, this is possible using setPoseTool(). You can set the active tool as an item or as a pose. You can also use setPoseFrame for reference frames.
Seems like changing active tool does not work in C++. Could you please double check it?
Are you using the latest version of RoboDK? Are you trying to set the tool as a pose or as a tool pointer?
It would be great if you can share a sample script file that shows the issue.
Thank you,
