Changing postpocessors through a python API for varying robot programs
Hi RoboDK team,
I want to ouput multiple robot programs for a single robot movementes through a python API.
For example, a particular block of robot movements should be exported through KR C4 whereas other block of robot movements should be exported to a Kuka.CNC program.
to explain:
// defined parameter: imports, robot, robot_base, path etc.
RDK.setRunMode(3)
post_processor = "KUKA_KRC4"
robot.setParam("PostProcessor", post_processor)
RDK.ProgramStart('Prog1', path,  post_processor, robot)
// movements for Prog1
RDK.Finish()   //finish the movements for Prog1 and export a KR C4 program
RDK.setRunMode(3)
post_processor = "KUKA_CNC"
RDK.ProgramStart('Prog2', path,  post_processor, robot)
// movements for Prog2
RDK.Finish()   //finish the movements for Prog1 and export a KUKA_CNC program
// Further moves
This should be possible. The sample code you shared looks like you are heading in the right direction.
What issues did you have?
Thanks for the response. I tried a code similar to my sample code and realized, the program exports just the prog1 and neglects everything after the first RDK.Finish() command.
I mean, the movements of prog1 are only exported as the .src, I dont get Kuka_CNC.
I believe it should work if I create multiple functions that export particular robot program. Like Def prog1(movements_for_prog1) Def prog2(movements_for_prog1).
But I would like to have it similar to the one I described above.
Can you share your script here with a demo station, this will help us help you.
Attached is a demo example.
The station has a example program (python) that switches in between the postprocessors.
I have added some comments, the code throws a error when RDK.Finish() is called, if I comment the RDK.Finish() function in between the code the, simulation works smooth however the desired output i.e. 3 seperate robot programs are not produced instead a single robot program (KRL) is obtained.
Please let me know!
P.S. Please define a output path in the python program main
Best,
Pradnil S Kamble
.rdk   Example.rdk (Size: 1.18 MB / Downloads: 724)
You can fix the issues in your script by making these modifications:
  1. You should call RDK.Connect after RDK.Finish (workaround, for some reason the API is not recovering/reconnecting automatically)
  2. The path to the posts folder for Program start should be a valid path so you don't see a popup to save the program.
  3. The name of the post processor should exactly match the post processor file in the Posts folder, it is case sensitive.
I attached the modifications I did to your script to make it work.
    # Use the KUKA CNC post
   RDK.setRunMode(RUNMODE_MAKE_ROBOTPROG)
   RDK.ProgramStart('Hex', r"C:/Users/UserName/Downloads/", post_processor, robot)
   # new target on active base
   base_target = park = RDK.AddTarget("Base_target", base)
   base_target.setAsCartesianTarget()
   base_target.setVisible(False)
   xyzabc = [0, 0, 0, 0.0, 0.0, 0.0]
   base_target.setPose(KUKA_2_Pose(xyzabc))
   robot.MoveL(base_target)
   # make a hexagon there
   poseref = base_target.Pose()
   for i in range(7):
       ang = i*2*pi/6 #angle: 0, 60, 120, ...
       posei = poseref*rotz(ang)*transl(100,0,0)*rotz(-ang)
       robot.MoveL(posei)
   robot.MoveJ(base_target)
   #End KUKA CNC program
   RDK.Finish()
   RDK.Connect() # Important if you want to continue using the API
   # Go back home with  KRC 4
   RDK.ProgramStart('Home', r"C:/Users/UserName/Downloads/", post_processor, robot)
   robot.MoveJ(robot_base)
robot.MoveL(...)
   RDK.Finish()
Thanks Albert and Jeremy!
This is now resolved.
