01-10-2025, 02:49 PM
Hi, new here. I've been trying to simulate additive manufacturing tool paths generated by CAM software by modifying the supplied samples. I have been able to pull the bead dimensions out of the NC program, but after setting the initial bead dimensions, cannot change them using the 'Spray' functions for programs with multiple bead sizes. I have found 'Spray_add', 'Spray_clear', 'Spray_On' and 'Spray_Off', but haven't found anything like 'Spray_Modify'. If I call spray add multiple times, it just adds the beads together, which I guess makes sense since you are really creating a cloud of spray droplets. Would I have to create a tool for every unique set of bead dimensions and use 'WeldOn' and 'WeldOff'? - Best regards, Bob
