Compliance Units in RoboDK Model
Hi everyone,
I am trying to create a twin kinematic model of an existing robot calibrated through RoboDK. I am having troubles whenever considering joints' compliances, so there are offsets between the data from RoboDK and the computed one using the twin model. I was wondering what are the units of the stifness in the attached figure. Also are such numbers related to stifness or compliance?
Thank you
Davide
Attached Files Image(s)
If your goal is to export the kinematic model from RoboDK to your robot I recommend to to remove the stiffness parameters. It is better to use the kinematic simplified set of parameters to export the kinematics to the robot controller.
