03-28-2023, 01:00 PM
I managed to connect RoboDK to a single UR5e robot and run the programme from computer on the physical robot very well. However, it did not work when the second UR5e was connected to RoboDK (there were two Ethernet cables to connect to each robot separately).
I thought that the issue is: there were two static IP addresses (say 192.168.0.1 and 192.168.0.2) assigned in the PC to each Ethernet. But when I tried to connect both robots, it seems only one of the IP addresses was working, the other Ethernet has be assigned a new and irrelevant IP address so that it actually was ignored. I am not sure if that is the reason. It would be very helpful if you may let me know if it is feasible to connect and run two robots and if yes how to do that properly .
Thank you very much.
