08-28-2020, 09:34 PM
Hi all,
I have a UR10e that I have connected to RoboDK and can successfully run programs off of. I am currently exploring the ability to use RoboDK's GUI to do online programming and am running into an issue when controlling the I/Os.
If I want to set the I/Os on the controller, the GUI I/O button works fine (Digital Outs Named IO_0 thru IO_7 in RoboDK map correctly to the URs DO0 thru DO7 for example). However, to control the Tool I/O I am running into issues where I am not able to trigger them through this same command.
Looking into the polyscope commands, I discovered that "set_standard_digital_out" controls the controllers digital outputs while "set_tool_digital_out" set the tools digital outputs. My first thought was to just inject this code into the tree through the "insert code" instruction, but I found out through this thread that this is not a supported feature.
https://robodk.com/forum/Thread-Insert-i...rsal+Robot
Am I overlooking something, like maybe just calling the IO by the wrong name? (UR documentation indicates it is called TO0, TO1, but I have also tried IO_8) Or is there no way to control the UR Tool I/Os through GUI commands?
Thanks in advance!
Trevor
Thanks in advance!
Trevor
