Threads: 7
I an trying to copy some folders and CADs, from one station no another, but it seem Ctrl C, Ctrl V doesnt work for that. Any ideas to solve it?
Threads: 7
Actually, just realized I need no double click old station to make it active and copy.
Than double click the new station to make it active and paste.
Thx
224
If you want to copy objects from one station to another you should use the same instance of RoboDK and copy first the objects or any items from your station. Then, open another station or make the other station active by double clicking on it (if you had it open already). Then, you should paste your objects.
You can also merge two RoboDK projects in one by right clicking at the root of your station, click on Add Item and select the second station you would like to include with the first one. This will keep all your internal links within targets, robots, programs, etc.
