10-26-2021, 09:22 AM
(This post was last modified: 10-26-2021, 09:26 AM by AgentMuellermilch.)
210923T2Object.rdk (Size: 2.63 MB / Downloads: 742)
Hello and thanks for your work.
I have a question about the curvefollowproject(CFP).
When I get a program out of the CFP, the Referenceframe of the Programm has got a different pose than the one I was referring to in the CFP-Options. I can look up the Frame Pose when i click on show instructions of the program.
I found out, that I can change this behaviour, if I go to Tools-> Options->Program… and deactivate the checkbox "Impose original tool and reference in programs".
But when I do that, the frame is correct, but the robot will move wrongly.
Why is that? I would like to have the unchanged reference frame, which I chose in the CFP Options with the correct curve movement. Maybe there is an easy solution to get that.
The Pose should be:
[ 1.000000, 0.000000, 0.000000, 1238.000000 ;
0.000000, 1.000000, 0.000000, 46.000000 ;
0.000000, 0.000000, 1.000000, 557.000000 ;
0.000000, 0.000000, 0.000000, 1.000000 ];
But changes to:
[ 0.000000, -0.000000, 1.000000, 1150.000000 ;
1.000000, 0.000000, 0.000000, -92.000000 ;
-0.000000, 1.000000, 0.000000, 557.000000 ;
Thank you in advance.
Blessings
Alex
