Cutting a machining project path
is it possible to cut a path generated from an APT to solve the not reachable target problem?
Regards,
For now, there's is no way to do that directly in RoboDK. (I recommend you to write a suggestion in the "Request new feature" section of the forum.)
You can split the APT file manually, you might need to duplicate the header and footer of the .apt program.
You can also split it the CAM software.
