DaihenDriver.exe Connection to OTC Daihen FD11 controller
Hi
Im trying to connect to Daihen OTC Fd11 controller
I recveivee error in  log:
Cannot start C:/RoboDK/api/robot/DaihenDriver.exe
Failed
Stopped
Starting robot driver: C:/RoboDK/api/robot/DaihenDriver.exe
Starting...
Error: Process failed to start:  (id 0)
Failed
DISCONNECT
Driver DaihenDriver not running
Where Can I get Daihendriver.exe?
I cant find it in my Robo DK API Robot folder.
Anyone connected to OTC controller?
Or I can only generate programs with Daihen postporcesor and loaded with USB?
Best regards Thenks for your help.
Tom
Hi Tom,
We don't have a driver for Daihen OTC robot. I recommend you to generate programs offline.
I assume you have a Nachi AX or FD controller?
If the robot controller supports FTP transfer you should be able to automatically transfer the files by right clicking the program and selecting "Send program to robot".
Hello Albert,
Yes, it is Nachi FD11 controller.
I just realized it is a Nachi controller.
So I will try to establish an FTP connection.
Do you know if I can jog with the robot and somehow use the get position command? It would be helpful with preparing robot programs offline.
regards
Hello, please allow me to jump in this thread.
I am not familiar with robot drivers, but our customer would like to export program to Daihen robot.
I do not think RoboDK has Daihen robot driver, but does it mean it is possible to transfer programs by using Nachi AX or FD controller instead?
Thank you for your support.
Hiroe
Hi Hiroe,
Yes, you can export programs by using the OTC post processor. You don't need the robot driver to generate robot programs offline.
This post processor is the same as the Nachi post because the controllers are the same.
