Difficulty adding python program to projects
I am receiving an error message when I add a python program in my robodk projects. Kindly note the error message in the inserted image. Will appreciate your guidance.
.png   robodk_capture.PNG (Size: 18.59 KB / Downloads: 588)
I believe this error is related to Python 2. If you use Python 3 it should work. You can set the Python interpreter in Tools-Options-Python.
If this is not the case, can you share the RDK file?
Many thanks. I changed the path from python 2 to 3 as you advised and it has worked.
regards,
Eza
