Disable Overwriting User Frames and User Tools on Fanuc Systems
Is it possible to disable using the position registers to write values into a user frame or user tool when making an LS file for Fanuc robots? I have included an example from an LS file.
8:  PR[9,1]=3584.350 ;
  9:  PR[9,2]=-1988.660 ;
 10:  PR[9,3]=1122.330 ;
 11:  PR[9,4]=0.000 ;
 12:  PR[9,5]=0.000 ;
 13:  PR[9,6]=-180.000 ;
 14:  PR[9,7]=0.000 ;
 15:  UFRAME[28]=PR[9] ;
You want to refer to an already known TCP or UF on the controller?
Simply name your tool or frame "Something 1" and it will refer to UFRAME[1] or T[1].
(If it doesn't work try removing the "space" before the number).
