Display Path/Trace of non-tool objects
I have a sphere attached to my tool as a separate object which I want to track. It would be optimal if this was possible either by using "Trace" or "Display Path" but I am open to other solutions as well. To be clear, I don't need to track the TCP at the same time (but it would be a nice plus).
Is it possible to track or display the path of objects that are not the active tool? If so what do I need to call for that?
Best regards
Nico
It is not possible to track the trace of non active tools by using the user interface but you could use the RoboDK API.
On the other hand, you could have a script running in an infinite loop adding points or targets as the robot moves.
Example:
frame = robot.Parent()
while True:
 posei = robot.SolveFK(joints) * tool.PoseTool()
 tracei = RDK.AddFrame("Frame", frame)
 tracei.setPose(posei)
Also, this example is a good start point that shows how you can monitor the robot joints in an infinite loop while checking the robot joints changed before adding a new target or frame:
C:/RoboDK/Library/Macros/MonitorJoints.py
