Dobot E6 is not properly modelled
I am currently working on Dobot Magician E6 robot with educational license of RoboDK. I have connected the robot to RoboDK using TCP mode, also I am using a suction cup I have also created the work station and tool with exact dimensions, and my tool is simply creating a z direction offset hence I am not using Tool Center positioning (I have used Tool Center positioning before it shows the exact value with minor decimal offset).
My problem is that when I try to use 'Run on Robot' it moves the robot exactly like simulation but it then collides or does not reach the point it is supposed to be at first (here I have used manual jog to see where my robot lands when I try to bring him out to touch outer most corner but it doesnt shows up in software).
I though I may have not calibrated the robot correctly so I ran a calibration using Dobot studio and then on RoboDK for TCP using 8 points while removing all the points with high error on the graph then also the error persists and also I am seeing huge difference between the cordinates between RoboDK and Dobot studio which might be the reason that it is showing the errors also the joint angle and base cordinate reference is same for both software then the x y z cordinates should also be same but it isnt please help RoboDK team.
.rdk   dobot_e6.rdk (Size: 683.1 KB / Downloads: 218)
.zip   Robodk_objects-20260614T153801Z-3-001.zip (Size: 663.28 KB / Downloads: 256)
It could be that the base and/or the tool is off by 180 deg or so. Could you send us a list of points providing the joint values and the Cartesian values of the tool flange with respect to the robot base? We can make sure the robot is properly modelled. It would be best to start with the home position and move one axis at a time by 10 degrees or so.
i have tried to move each joint one by one please have look at the pdf
.pdf   points and joint updated.pdf (Size: 27.81 KB / Downloads: 161)
Thanks for such detailed information. It looks like the tool RZ was off by 180 deg and the Euler format was not properly set.
You should follow these steps to fix the kinematics issues.
  1. Senect Parameters.
  2. Check the option Unlock advanced options
  3. Set Euler Angle type: Generic
  4. Set the tool frame RZ value to 180 deg
See the attached image:
We'll soon fix this in the library and let you know.
.rdk   dobot_e6-fixes.rdk (Size: 683.53 KB / Downloads: 273)
The coordinates from Dobot Studio still do not match those from RoboDK. I know that the values provided by RoboDK are correct, but Dobot Studio seems to be interpreting them incorrectly. Can you suggest any solutions?
I understand you are using the driver.
Did you set the user coordinate system and the tool at zero on the real robot?
Can you try generating a program and running it on the robot?
I have set both base and tool to zero in Dobot studio but the issue still remains while running robot on driver as well as on generated program.
and can you also explain how do we turn on the tool also using robodk
.mp4   WhatsApp Video 2026-06-23 at 10.20.11 AM.mp4 (Size: 3.35 MB / Downloads: 139)
.mp4   WhatsApp Video 2026-06-23 at 10.20.04 AM.mp4 (Size: 3.37 MB / Downloads: 155)
After investigating the dobot_api_v4.py file, I tried printing the generated string. I realized that the joint values were always consistent between RoboDK and Dobot Studio, but there was a mismatch between the position values in RoboDK and Dobot Studio. Hence, I tried to force the robot to use MoveJ(pose=...), and it was consistent, but it was still populated with the joint values from RoboDK, which is not desired.
(It is risky to perform this test. Please use only positive joint angles with higher values so that the robot doesn't slam into the ground.)
So, is there any way to populate my MoveJ command using only the position values, as the joint angles are not giving me the correct output?
although why it is happening is some thing related to the DH parameter itself i guess
api edited code
after editing api
dobot studio
I'm sorry for the late reply on this thread. I believe that you should not change the MovJ function from the Dobot API. I'm surprised if this worked. It means the robot API mixes joints and poses.
Do you have any issues if you use the post processor?
Can you try again with the latest version of RoboDK and test the driver and the post processor?
If the issue persists: Can you share the RoboDK project file you used for testing? You should not have any issues if you use joint targets for joint movements and Cartesian targets for linear movements. If you can share the robot log as text when you print the commands it will be helpful.
Right now I am not in that company but I will brief what was the issue
Actually Robodk is sending the joint values correctly
The real problem is that home cordinate of robot in robodk is slightly higher than the home cordinate of robot in dobot studio which can easily be changed by changing the global cordinate system of robot in dobot studio.
At this point both robodk and dobot studio had same home cordinate system but when I moved the robot to another point their were lot of inconsistency in all cordinate of x y and z but joint angle were matching on both simulation and on real robot
hence I tried to reverse the role by making the cordinate consistent between dobot studio and robodk by writing a forward kinematics of my robot arm converting angles to position and used that position value in dobot driver to drive my robot.
I am not very aware how to use post processor file so I can't answer on that
Conclusion is that cordinate of robot in robodk doesn't match to the cordinate of robot in real life.
U can go through the code attached in the pdf I made and can paste it in your driver for a temporary fix for operation but I would love to see that joint values result in correct cordinate which will full potential of robot sim
Btw are you guys hiring for any technical role or can u give me a intership I would like to apply thanks 🙏🏻
https://lnkd.in/p/dVhD2VEW
Video of operation
.pdf   DOC-20260718-WA0005..pdf (Size: 274.51 KB / Downloads: 9)
