02-29-2024, 11:54 AM
Hello.
I have a problem with the Example-07.d-Drawing with robot and I don't understand which problem is it.
El script de Python ha fallado devolviendo 1
File "C:\Users\elvir\AppData\Local\Temp\Robot_paint.py", line 126, in from svgpy.svg import *
File "C:\RoboDK\Python-Embedded\Lib\site-packages\shiboken2\files.dir\shibokensupport\_feature_.py", line 142, in_import return original_import(name, *args, **kwargs)
File "C:\RoboDK\Library\Example-07.d-Drawing with a robot\svgpy\svg.py", line 3, in
from.path import Path
File "C:\RoboDK\Library\Example-07.d-Drawing with a robot\svgpy\path.py", line 3, in
from collections import MutableSequence ImportError: cannot import name 'MutableSequence' from 'collections' (C:\RoboDK\Python-Embedded\python310.zip\collections\_init__.pyc)
Salida de script de Python
This is the message it gives when I try to run the program but I can't figure out where it came from because I haven't even modified the code to change the image and it doesn't work.
If anyone could help me fix this please.
Thank you in advance.
Elvira Puente Cáceres
