08-10-2023, 02:09 PM
I'm getting an error "Error in JOB data record(J:t1 L:****) [13]" on my Yaskawa Motoman HC10DT when I try to load Job from USB (shown on Picture 1).
When I was in first phase of testing, I only created two random points in RoboDK in 3D space and used Motoman Cartesian as post processor, created .JBI file, copied it on USB, loaded it normaly in HC10DT pendant and worked perfectly. This job in .JBI in Notepad++ is shown in Picture 2.
Then I proceeded to add few steps by creating simple "Face Milling" operation in Mastercam and installed RoboDK Add-on. I managed to import the part and the path to RoboDK and I placed it in space near HC10DT (Picture 3). Same post processor was used but the generated job looked different.
First difference I noticed was the ///POSTYPE PULSE and ///POSTYPE BASE were used combined (Picture 4). I found on some other forum that someone talked about that and they said someone from RoboDK provided them with new post processor that fixed that. (Picture 5) The link is from site Robot-Forum: CLICK HERE
Second thing I noticed it added CALL JOB:SetTool and CALL JOB:SetRPM1 (Picture 6). I do not have those JOBS in Motoman memory, don't know if that is even relevant. I tried deleting those, didn't work.
Also, it added 'Setting Tool 9 (Set Tool): ...... (Picture 6)
I found on some other thread that we should check values of TCP on robot and in program. I checked if my tools had correct values on robot controller, they had. (Picture 7, 8 and 9)
I will provide .JBI and .rdk of non working station in the attachment bellow.
Thank You for Your feedback and Your help in advance.
Vanja Makaj
HC10DT Error.zip (Size: 22.56 MB / Downloads: 637)
Vanja Makaj
