Error when using shape Add-in
I'm getting an error when i try to use the shape Add-in.
Using version 5.4.1
Updating RoboDK to the latest version should fix this issue:
https://robodk.com/download
Alternatively, to fix Python related issues involving the API you can try updating the API to the latest version by following these steps:
  1. Select Tools-Run Script
  2. Select Install Python Package
  3. Enter robodk and select OK
I dont see that option in the Run Script list.
You can then drop the file attached here:
C:/RoboDK/Library/Scripts/Install_Python_Package.py
.py   Install_Python_Package.py (Size: 923 bytes / Downloads: 515)
Thanks !
