External rotary axis mounted on robot wrist (A6)
I am working on a filament winding simulation in RoboDK.
My setup is:
- A 6-axis KUKA robot
- An additional rotary axis (E1) mounted directly on the robot wrist (A6)
- The mandrel is attached to this E1 axis
The key point is that this external axis is mounted on the robot flange (A6), not on the base.
The E1 axis is coaxial with A6, so from a kinematic perspective it could be merged into A6. However, I would like to keep it as an independent axis for control purposes.
My questions are:
1. Does RoboDK support adding an external axis directly on the robot flange (A6)?
2. If not, is there any recommended workaround to simulate this configuration?
3. Can this be achieved using the Python API by synchronizing a virtual axis?
My goal is to simulate coordinated motion where:
- The mandrel rotates continuously (E1)
- The robot mainly controls the tool orientation
Thanks in advance!
.rdk   star1.rdk (Size: 5.42 MB / Downloads: 411)
I think you could create one rotative axis mechanism, then use Utilities > Synchronise External Axes to sync up the robots.
You won't be able to properly synchronize and use an axis mounted on a robot.
I would recommend you to leave this axis as a positionner or as a static object. You can make the simulation more advanced by using a custom integration using the API.
