ExtruderSpeed() function for 3D printing with ABB IRB120
#11
(12-30-2020, 01:04 PM)Jeremy Wrote: Hi Otto,
This is because the Motoman post-processor is limited to 7 characters, anything longer than that will be truncated.
What you can do is go to your "Program Events" in your "3D printing project".
On the right, you will see "Extrude(%1)", simply enter "E(%1)" and you just saved 6 characters for the numbers.
Let me know if it helps.
I never job calls with parameters on a Motoman, so I don't know what is the exact syntax.
If anything, I can help you with that.
in Yaskawa, it is not possible to use numbers with decimals as an Argument, Only Integers are allowed. But In ROBODK I become the speed of extruder as integer and decimal value for example :
Call Extruder (1510.560)
Is it Possible to get the number only in Integer form like:
Call Extruder(1510)
Please see the attached Photo?
BR
Hi Otto,
Here's a new post-processor that should remove the decimal.
You can then divide by 100 000 once you retrieve the value in the controller.
Hope it helps.
.py   Motoman_Extruder_Decimal.py (Size: 42.28 KB / Downloads: 740)
#13
(01-20-2021, 05:30 PM)Jeremy Wrote: Hi Otto,
Hope it helps.
I added the new post-processor to my program but unfortunately, it didn't solve my problem. I still have the decimal!
Otto
#14
Hope it helps.
the problem is partially solved.
At first, it didn't work, because I found in the Python File that the dot is missed (.)
 # Remove special characters
   for c in r'-[]/\;,><&*:%=+@!#^()|?^ ':
       progname = progname.replace(c,'')
After Adding the dot the problem is solved.
But I got now the program in such form:
CALL JOB:EX61356
MOVL C00341 V=60.0 PL=1
CALL JOB:EX61576
MOVL C00342 V=60.0 PL=1
CALL JOB:EX61576
MOVL C00343 V=60.0 PL=1
and in Yaskawa, it is not acceptable to call a program without space after program name (EX), and also the argument has to be between Brackets like below:
CALL JOB:EX  (61356)
I tried to give the brackets and space in the Program Events but no gain...
can you please guide me to solve this issue?
THANX!
Otto
#15
Hi Otto,
Could you join your .rdk station so that I can test the modification before sending it to you.
#16
(01-26-2021, 05:34 PM)Jeremy Wrote: Hi Otto,
Please find the attached file.
Thank you:-)
.rdk   Motoman_SPS_LOGO.rdk (Size: 6.61 MB / Downloads: 821)
#17
Hi Otto,
I think that this one should work.
Hope it helps.
.py   Motoman_Extruder_Decimal.py (Size: 42.39 KB / Downloads: 758)
#18
@Jeremy
Hello. Is it possible for Robo DK to generate extrusion commands in a way that Marlin firmware understands? For example instead of ExtruderSpeed or Extrudelength, is it possible to show G1 Evalue and F value from Slic3r in the code generated by Robo DK?
#19
Hi Fahadak89,
I'll need a bit more information to answer you properly on this one.
Can you provide de G code from Slic3r and provide a small example code of what you would like RDK to generate.
That would help point you in the right direction.
#20
Hello Jeremy,
The G code file is attached with this message. I am having on more problem. When I am saving the robot program through Robo DK, it removes the decimal point from the extruder values. When I am showing the instructions of 3D printing program in the software environment, I can see the decimal with every extruder number but when I save the program, the decimal is gone. I am attaching the code file as well for your reference.
.mod   heart3DPrinting.mod (Size: 1.02 MB / Downloads: 715)
.txt   Heart G Code.txt (Size: 155.09 KB / Downloads: 1,030)
